August 7, 2002, 11:10 |
GRID
I am a Phoenics user I've got some problems with the grid. In my model fairly small inlets are present, the small inlets (0.008 in thicknes) are probably not working. This may be cause the are too small comparing to the grid or tolerance (0.085) of the grid. Is there a relation between the tolerance and the dimensions of the inlets?? Another problem: I would like to have the grid exactly fitting to the inlet borders. When I am in a object dialogue box of a certain inlet and set "object affects the grid" to YES, I do not see it back in the grid. hopefully anybody can give me some suggestions, Thanx, Marc. |
August 7, 2002, 11:31 |
Re: GRID
Please send me q1 file. I will check it and can suggest some thing. Pl. use SI units in your problem. Vikas
August 7, 2002, 13:17 |
Re: GRID
You can try with tolerance 0.005 inch: Vikas
file reread-grid (reading new grid w/o wiping out | John McKelliget | FLUENT | 4 | January 11, 2007 03:32 |
to Identify unstructured grid and structrued grid | harry | Main CFD Forum | 4 | February 17, 2006 02:10 |
FOAM use a staggerd grid or collocated grid system | ztdep | OpenFOAM Running, Solving & CFD | 0 | September 15, 2005 11:53 |
coarse grid to fine grid crashing | Arnab | Siemens | 1 | February 22, 2005 12:27 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
