January 16, 2007, 19:16 |
run time error
Hi all While running a case i am getting a run time error can any one help me out how to get rid of this.
Thanks in advance Manjinder Singh |
January 17, 2007, 11:46 |
Re: run time error
You might need to check your setting carefully. For example, your Q1 file. If you are using a computer connected with a local sever, Phoenics might be interrupted by some adjustment of sever. If this happenes, you can re-set your computer time to the date before the appearance of this error message. Hope it helps.
April 3, 2007, 14:54 |
Re: run time error
If u use ground.for, it may cause a run-time error when there is a illegal function such as divided by zero...,It is difficult to tell the exact resolution but I suggest u to check your self-defined function first.
Run time error | chakradhar | FLUENT | 1 | February 26, 2007 13:32 |
run time error | Jian zhang | Fidelity CFD | 2 | June 12, 2006 10:06 |
Fortran Run Time Error | bv | Siemens | 7 | September 9, 2005 07:02 |
run-time error | Sileno | Phoenics | 7 | September 7, 2005 09:39 |
run-time error M6203 | Thomas | Main CFD Forum | 1 | May 20, 2005 07:51 |
