June 7, 2007, 08:26 |
circular FAN object with IPSA
I need to make the cylindrical swirl two phase flows at the inlet in cartesian coordinate system. For the one phase flow I used the circular FAN object. In two phase flow the FAN object doesn't work. How I can introduce the swirl two phase flows at inlet? Thank you all in advance, Sergiy |
July 11, 2007, 19:36 |
Re: circular FAN object with IPSA
This is probably not a very good suggestion, but I have created several inlets with vectored inputs to form a swirling ring...
How to determine the type of an object in the object registry | mwild | OpenFOAM Running, Solving & CFD | 8 | June 8, 2010 20:58 |
IPSA | Foram | Main CFD Forum | 0 | January 15, 2008 01:05 |
IPSA | p kumar | Phoenics | 2 | December 31, 2002 03:13 |
flow around a circular object | Mavinakere | FLUENT | 3 | February 10, 2002 14:27 |
IPSA algorithm | Maltsev Alexander | Main CFD Forum | 1 | February 6, 1999 11:33 |
