transport equation for entropy
Old   September 23, 2011, 15:14
Default transport equation for entropy
ISAAC HERNÁNDEZ ARRIETA
Jango_fett is on a distinguished road
Good day, I would like to ask something, expecting someone answer my question.
Does someone know if Phoenics can solve or have the option in order to calculate the entropy production?
I'm interested on calculate the irreversabilities into a heat exchanger where a turbulent flow pass through fins.
I will be very greatful, if someone can help me or give me information about if is Phoenics can calculate the entropy by using the transport equation
Nice day
Jango_fett is offline   Reply With Quote
Old   October 17, 2011, 05:55
Default Entropy production in PHOENICS
michael malin
phoenics_cfd is on a distinguished road
One could compute the entropy production rate as a post-processing exercise by simply adding the contributions due to viscous and thermal effects. An example of such an approach has been given by F.Kock & H.Herwig, "Entropy production calculation for turbulent shear flows and their implementation in cfd codes", Int. J. Heat & Fluid Flow, Vol.26, Issue 4, p672-680, (2005). This sort of approach can be implemented very easily in PHOENICS by using the INFORM facility.
A more elaborate approach would be to select and solve one of the scalar variables provided by PHOENICS, i.e. C1 or C2 or C3, etc. The necessary entropy production terms can be introduced into this transport equation, again by the use of the INFORM facility. Various forms of the modelled transport equation for entropy can be found in the literature, see for example: M.Safari et al, "Entropy Transport Equation in LES for Energy Analysis of Turbulent Combustion Systems", Entropy, 12, 434-444, (2010).
phoenics_cfd is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
UDF Transport equation for transition momentum thickness Reynolds number Wantami FLUENT 0 April 9, 2011 02:50
Source Term on Scalar Transport Equation - crashing simulation alessio.nz OpenFOAM 19 February 8, 2011 07:38
Is it possible to use divergence in the source term of an scalar transport equation? jannnesss CFX 0 January 8, 2010 19:53
