Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
Guidance required for making a C grid in pointwise
Old   June 15, 2012, 02:02
Default Guidance required for making a C grid in pointwise
venkat
junkie71189 is on a distinguished road
Hey guys,
I'm new to using Pointwise and I was wondering if there was a simple way of making a C-grid for a flow over an airfoil case?
In gridgen, I remember that we could choose the same connector twice to extrude in different directions that made life easier. However, I'm not able to find any easy way out in Pointwise. (I also couldn't convert the 2D gridgen mesh to 3D in pointwise)
Also, I had great difficulty in making a grid when the trailing edge was not sharp. How do we tackle that situation?
I tried making one on my own by some regular geometry methods but after using the output polymesh files, the case didn't work.
Help would be very much appreciated!
Thank you in advance
Venkat
junkie71189 is offline   Reply With Quote
Old   September 5, 2012, 15:59
Elh. A2. BAH
ebah6 is on a distinguished road
Hi Venkat,
Did you figure out how to do your C-grid in Pointwise?
If so, can you post your findings.
Best regards.
ebah6 is offline   Reply With Quote
Old   December 20, 2012, 12:42
venkat
Hey,
Unfortunately the C-grid didn't work out quite so well even though it looked good. I ended up using a blockMeshDict file for my findings. This was better but not quite accurate enough specially for drag at lower angles and don't predict stall well enough.
airfoil, pointwise
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
Algebraic Multigrid for nonuniform grid Joshua Lee Main CFD Forum 4 March 16, 2000 13:05
Non-uniform grid calculation Aspens Main CFD Forum 1 February 23, 2000 14:15
Grid Quality and the Solution Faraz Main CFD Forum 4 January 10, 2000 18:18
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 22:26
