Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
structured mesh for a coil
Old   April 17, 2013, 05:51
Default structured mesh for a coil
James
James_ is on a distinguished road
Dear users,
I’m trying to prepare a structured mesh for a coil (fig.1). I decided to apply a square block inside the coil (fig. 2). I also prepared a boundary layer block . Now I want to create essential domains (one of this is shown in fig. 3) and build four blocks between square core and boundary layer blocks. I added two connectors highlighted in fig. 2 but obtained mesh is tragic (fig. 3). Frankly, I don’t have any idea how to avoid this problem. (I suspect that domain created on database can generate this problem).
I also created square core using only connectors (fig. 4) but these blocks contain negative volume elements.
Could you give me any suggestions?
Best regards
James_ is offline   Reply With Quote
Old   April 17, 2013, 08:15
Chris Sideroff
cnsidero is on a distinguished road
James_,
Do you have or can you create a curve for the center line of the tube? If so, the easiest approach would be to create the 2D mesh you want at the inlet and then sweep those domains along the center line using the path based extrusion.
-Chris
Originally Posted by James_ View Post
Dear users,
Best regards
cnsidero is offline   Reply With Quote
Old   April 17, 2013, 16:15
James
Thank you very much Chris
it works perfectly
your help is indispensable
coil, pointwise, structured mesh
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
Block structured hexagonal mesh vs automated tetra mesh inside Workbench for CFD Chander CFX 3 November 27, 2011 16:24
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
