April 19, 2015, 19:31 |
Pointwise: Extrude/Rotation
Jenna
Rep Power: 11 |
Hi, I am trying to rotate my 2D domain for a spray into a 3D cylindrical domain. My imaged is attached
It is an unstructured mesh (not the best, but this is just practice). what would be the best way to go about creating an extrude with such a domain? Also, if I wanted to created a 3d rectangular domain from this, how would that be done? (preferably without coding) I have messed around with all the options of extrude>>rotate in pointwise with no luck. Any help would be appreciated! |
April 21, 2015, 10:30 |
David Garlisch
Location: Fidelity Pointwise, Cadence Design Systems (Fort Worth, Texas Office)
If you are doing a extruded rotation, you have too much grid.
Remove the domains and connectors from the lower half of your grid (below the center, symmetry connector). The extrude rotate the remaining domains using the center, symmetry connector to define the rotation axis. Last edited by dgarlisch; April 21, 2015 at 10:37. Reason: added image |
April 24, 2015, 15:51 |
Jenna
Rep Power: 11 |
Thanks for responding to my question and giving input.
Is there a way to determine how many steps you should use when rotating? (please ignore thumbnail) |
April 24, 2015, 19:05 |
David Garlisch
Not that I can tell you. It totally depends on the needs of the simulation you are running.
But basically, each step will produce a layer of extruded cells in the rotation. Quads will extrude to hexes, Tris will extrude to prisms (wedges). |
[Commercial meshers] Pointwise to Foam - cyclic BC points order | Pj. | OpenFOAM Meshing & Mesh Conversion | 5 | August 14, 2016 04:47 |
Build Topology in Pointwise & Local Surface Refinement | nnprashant | Pointwise & Gridgen | 1 | August 25, 2014 09:26 |
generating OpenFOAM meshes with pointwise | robo | OpenFOAM Pre-Processing | 1 | April 29, 2014 13:47 |
[Commercial meshers] Native OpenFOAM interface in Pointwise | cnsidero | OpenFOAM Meshing & Mesh Conversion | 41 | May 20, 2012 18:30 |
Native OpenFOAM interface in Pointwise | Chris Sideroff | Main CFD Forum | 0 | January 16, 2009 12:37 |
