March 25, 2020, 17:17 |
Axis Symmetric Mesh for OpenFOAM
Gurpreet Singh
Rep Power: 9 |
Hi Pointwise Experts,
I am working on CFD simulation of axis symmetric problem using OpenFOAM as a solver and Pointwise a s a Meshing tool. I am attaching the geometry here for reference. I am very new to Pointwise Meshing tool. I am looking for your valuable advice on this geometry to know whether Structured meshing is possible in this case or I should go for unstructured meshing. (1)I want to make axis symmetric mesh for openfoam. (2) I tried to make a simple axis symmetric mesh for cylinder using these steps.. * Made rectangle and created the connectors on it. * Then I Created the dimensions on those four connectors. * Created structured domain. Then I rotated the entire domain at an angle of 2.5 degrees using Edit - Transform- Rotate. * I applied Extrude- Rotate command to rotate the entire domain at an angle of 5. degrees to make the Block. * Applied all the boundary conditions like Wedge boundary conditions to front and back face. * Exported the mesh using File- Export- CAE. Can you please advise me how to mesh this type of complex geometry in Pointwise. Regards Gurpreet 1.jpg Capture.jpg |
March 26, 2020, 09:44 |
Gurpreet Singh
Rep Power: 9 |
Can anyone help me ?
March 26, 2020, 12:52 |
Pointwise Axisymmetric Mesh
Gurpreet Singh
Rep Power: 9 |
Hi Dear,
I made Axis symmetric mesh of this geometry using Pointwise for OpenFOAM. When I run the renumberMesh -overwrite utility, it runs without any problem. But the check mesh gives me one error like this *Wedge patch back not planar. Point (5.22212 1.74019 -0.0759782) is not in patch plane by 2.00397e-007 metre. and I am attaching the picture here for reference. I also attaching the Pointwise Mesh file here. You can find the fiels from the link below. https://spaces.hightail.com/space/No2upnuVf7 Regards Gurpreet CheckMesh.PNG |
March 30, 2020, 12:56 |
David Garlisch
Location: Fidelity Pointwise, Cadence Design Systems (Fort Worth, Texas Office)
The errors reported by checkMesh are very small (~2e-7). These kinds of small deviations can be introduced by Pointwise because of numerical round-off errors during the generation of the domain points.
To fix, try this:
Constraining the original domain and connectors to the plane will force all the points to be "highly planar" and should make OpenFOAM checkMesh happy. To verify the domain constraints, select the domain and use Menu Examine, Database Associativity... |
August 12, 2023, 11:09 |
#5 | |
Deniz
I did exactly what you said, but the error still persists. When I project onto the plane, the color of the errors turns purple. However, when I rotate, the color remains green after rotation. What could be the reason for this? I'm still getting the same error (*Wedge patch back not planar. exactly same as the above) using OpenFOAM. Best regards EDIT: I managed to solve the problem in a completely different way. Currently, openFOAM is not giving any errors. Still, thank you Last edited by Deniz58; August 17, 2023 at 03:10. |
April 25, 2020, 09:57 |
#6 | |
Radhe
Rep Power: 11 |
did you use 2d or 3d option in Pointwise to generate the mesh for axisymmetric case? Last edited by tanmay singhal; April 25, 2020 at 09:59. Reason: wrong syntax |
April 26, 2020, 22:10 |
Gurpreet Singh
Rep Power: 9 |
Hi Dear,
I used 3d option . |
axis symmetric, openfoam, pointwise |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 05:39 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
