Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
Propeller Meshing in Gridgen/Pointwise
Old   August 2, 2010, 09:25
Default Propeller Meshing in Gridgen/Pointwise
Semih Önel
ctrlaltdel is on a distinguished road
Hi everyone,
I'm a new user on gridgen and pointwise, trying to mesh the propeller.
As seen in the picture that I have just attached; there are three different domain volumes.
Firstly, I meshed the propeller surface, after that while meshing the volume2, gridgen ignored the propeller mesh and it meshed straight through from one surface of volume2 the other one.
Thanks.
ctrlaltdel is offline   Reply With Quote
Old   August 2, 2010, 13:16
Smile Add the propeller surface grid to the block face
rmatus's Avatar
Rick Matus
rmatus is on a distinguished road
It looks like the propeller surface grids did not get added to the block face, so they are ignored.
If the propeller surface domains attach to the domains that compose the existing face, then rebuild the block and make sure you include the propeller domains in the block face.
If the propeller surface domains do not attach to the domains that compose the existing face, then add the propeller domains as a second face in the block.
Hope this helps.
rmatus is offline   Reply With Quote
Old   August 6, 2010, 09:18
Semih Önel
Hi again,
I've solved the first problem another way, but now there is a different problem.
Firstly, I meshed the porpeller and first volume together as you can see in 1.jpg, after that I created second and third volume at pointwise and finished meshing.
When the mesh is imported into Ansys CFX-Pre workbench, what happened is in 3.jpg.
Although the second and third volume were imported, the first volume and propeller were not imported.
What can I do for this situation ?
Thanks.
Old   August 6, 2010, 09:55
Smile Select all blocks before exporting
rmatus's Avatar
Rick Matus
Make sure you have selected all the blocks you want to export before going to File, Export, CAE. This can be a little confusing if you used Gridgen before, because Gridgen always exports every block.
Pointwise gives you more flexibility and lets you choose which blocks to export to your CAE solver, but that also means you have to choose which blocks to export. I am guessing you only had one block selected when you exported the grid to Ansys CFX.
Hope this helps.
Old   August 6, 2010, 10:11
Semih Önel
Thanks Rick for your help, my mesh contains two bloks and I did selected both of them but it didn't work.
Hope this helps.
Old   August 6, 2010, 11:12
Post Not sure
rmatus's Avatar
Rick Matus
Hmmm, then I am not sure what is causing this. If you can send me the .pw file, I will try to figure out what is causing this.
There is one other thing you can try. Export the blocks one at a time and import them into CFX separately individually to see if there is a problem with one of the blocks.
3d meshing strategy for propeller in gambit Harikrishna FLUENT 3 January 12, 2012 06:38
propeller blade meshing Terence Fidelity CFD 8 July 15, 2008 13:31
Gambit & Propeller Meshing James Date FLUENT 7 July 6, 2004 16:54
Meshing a Propeller K.C CFX 1 October 22, 2003 18:20
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
