Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
Do you know these simple Gridgen questions?
Old   November 4, 2004, 17:10
Default Do you know these simple Gridgen questions?
GER
It is highly appreciated if you know and answer the following questions about how to use gridgen:
1) Can it read autocat file? How?
2) Can it output the grid (i,j,k,x,y,z) into a file that can be read by a fortran code? How?
3) how to generate a simple mesh for a cubic box?
I have the menu but no time to read for details. Thanks a lot for your quick answer.
GER
Old   November 5, 2004, 09:06
Default Re: Do you know these simple Gridgen questions?
ag
1) Not sure 2) Out your grid in Plot3d format 3) Generate a domain and one normal connector and use the block creation -> hyperbolic generator -> extrude along connector (if the version of gridgen you are using supports this).
Not to be snippy here, but these are fairly simple and routine tasks in gridgen. You need to make the time to pick these sorts of things up by working through parts of the manual.
Old   November 5, 2004, 13:43
Jarmo Monttinen
1) Can read IGES by default, you can get add-ons that allow you to read some other formats as well.
2) Plot3D is the easiest, you can basically output it in any format, it depends on the read statements in your code.
-- Jarmo
Old   November 5, 2004, 17:53
Default Thanks a lot to AG and JARMO
GER
Thank you two a lot. Ger
questions about SIMPLE algorithm (by Patankar) Nutty Main CFD Forum 5 January 22, 2015 12:22
LES basic and simple questions. dshawul Main CFD Forum 0 October 4, 2010 10:56
SIMPLE Algorithm - Questions from a Beginner Emre Turkoz Main CFD Forum 8 August 13, 2010 00:21
[snappyHexMesh] A few simple questions about SnappyHexMesh. suitup OpenFOAM Meshing & Mesh Conversion 1 December 19, 2009 14:30
Few simple questions concerning boundary conditions (pressure) milos OpenFOAM Pre-Processing 1 March 21, 2009 07:08
