May 25, 2021, 21:05 |
Output of force
Wenyu Zhao
Rep Power: 5 |
Hello! When I put the command o 33 44.0 2.50 0.35 in Tutorial_REEF3D_19.06 is changed to O 10 43.65 44.35 2.15 2.85 0 7,the other commands do not change, and they are displayed in the result file REEF3D_Force-1.dat.I want to get the force on the structure. How should I set it? Is the output of REEF3D_CFD_Forcesolid-1.dat the force of the terrain?
May 26, 2021, 02:40 |
Arun Kamath
Hi Andrea,
In order to include the structures and calculate forces on them, use the commands from Solids (S), in your case S 10. The force box is then defined around this solid (as might have already done in ctrl.txt using the P 81). The forces on the solid object is then output to the forcesolid.dat The O commands are now deprecated and will be removed soon.
Arun X years with REEF3D |
May 26, 2021, 04:35 |
output of force
#3 | |
Wenyu Zhao
Rep Power: 5 |
What's the use of REEF3D_Force.dat file? What is the force in this document? In addition, I set the structure to O 10 43.65 44.35 2.15 2.85 0 7, and the command force box is also fixed on the structure. Why is there a force output in the REEF3D_CFD_Forcesolid.dat, and what is the output force?There is no solid in the force box at this time. Shouldn't the REEF3D_CFD_Forcesolid.dat file be 0? |
Hydrodynamic force? | arun7328 | STAR-CCM+ | 24 | July 25, 2020 04:04 |
Drag Force Ratio for Flat Plate | Rob Wilk | Main CFD Forum | 40 | May 10, 2020 04:47 |
Forward simulations -- Evaluating objective function only without design modules | kensaii | SU2 Shape Design | 4 | April 25, 2020 15:12 |
What variable should I output to get wall force? | Pauli | CFX | 6 | May 15, 2018 07:58 |
udf for compute pressure drag force | fatemi | Fluent UDF and Scheme Programming | 1 | January 26, 2018 13:27 |
