Sediment is non-conservative when using 2-D setups |
January 20, 2022, 00:11 |
Bingchang Zhang
Rep Power: 4 |
I tried to validate the sediment model against Mao (1968)’s experiments. The experiments parameters are: the water depth was 0.35 m, the diameter of the pipeline was D=0.1m, the sediment diameter was d50=0.00036m, inflow rate is 0.4m/s (far-fields Shields number is 0.065). At first, I tried to use a 2-D setup (only 1 layer mesh along the pipeline), there is no sand dune at the downstream side of scour hole. that reflects the sediment may not be conservative. I also tried a 3-D setup (3 layers mesh along the pipeline), the sand dune appears, thus, I think the nonconservation problem only occurs 2-D setup. Could you please check this? (attached is my simulation result). Thanks in advance. Regards Bingchang |
January 21, 2022, 10:55 |
Verifying
Hernest
Rep Power: 4 |
Hello Bingcz
You could share your "control" and "ctr" input files to check in some of the commands if there is something preventing what you want to get. please. |
January 21, 2022, 11:04 |
#3 | |
Bingchang Zhang
Rep Power: 4 |
Thanks for the reply, attached is the input files, and geo.dat. Regards, Bingchang |
January 23, 2022, 12:58 |
Hernest
Rep Power: 4 |
hi bingcz
I have not been able to run the DiveMESH input file where the geo data is embedded. It shows me the following message. DIVEMesh (c) 2008-2020 Hans Bihs :: Open source meshing v_210519 Reading control open geo.dat and count the entries.. after that there is no progress and the program is stopped indefinitely. |
January 23, 2022, 21:39 |
#5 | |
Bingchang Zhang
Rep Power: 4 |
Hi Hernest, Please see the attached files, I appreciate your help. Regards, Bingchang |
checking |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Conservative discretization | arungovindneelan | Main CFD Forum | 1 | July 4, 2019 03:22 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
conservative or non conservative, Is there a big difference? | sharonyue | OpenFOAM Running, Solving & CFD | 1 | April 10, 2015 04:19 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
