CSET on a section
Old   January 14, 2002, 05:43
Default CSET on a section
Franch
How can I get a CSET on a section?
I need to do this to calculate the VAVERAGE on the section, to have average pressure.
It's forbiddend to get cells using cursor. If I select a zone I can't help getting other cells around.
Old   January 14, 2002, 05:45
Default Re: CSET on a section
HVN
cset news gran ?
Old   January 15, 2002, 01:19
Lars Ola Liavåg
Try creating shells on the section using the pscreate command and map the solution onto these shells. Then you can use the summarize command to get the mean value of your variables.
Old   January 16, 2002, 05:26
tobbe
if you have a hex-mesh you can try cset news layer then crossing a cell in the layer and two vertices to define the layer direction, see help cset If its the averaged pressure you want, I think the best way is to select a cset with the zone option that is so narrow as possible around the section where you want your average, define a section with the section slice button. Then by: getc u v w pstat inte cset you get your p average
Cross-Section sidd Siemens 2 March 10, 2008 04:14
cave cset vs vave vset MK Siemens 1 October 29, 2006 20:44
Help about the CSET ggbaby Siemens 4 September 18, 2006 12:13
New Section Ynot (previously jedi) CFD-Wiki 3 December 5, 2005 06:36
how to change the number of cset and vset lenson Siemens 3 October 10, 2005 06:40
