Deference between underhood and engine cooling |
July 28, 2003, 22:15 |
hay... anybody Is anybody know the deferences between underhood analysis and engine cooling analysis?
i confuse.. thank u.. best regard terry Henry |
July 29, 2003, 08:11 |
Re: Deference between underhood and engine cooling
An underhood analysis focuses on the external flow within the engine compartment of a vehicle (and usually the external aerodynamics as well). Working fluid is air.
When you speak of an engine cooling analysis, it usually refers to the flow of coolant (anti-freeze), throughout the internal passages of the cylinder head, engine block, water pump, thermostat, etc... Working fluid is water/glycol mixture. Incompressible flow. Good luck! Regards, cfdweirdo ;-} |
Underhood simulation | Suresh | Main CFD Forum | 0 | October 16, 2004 06:29 |
Regenerative cooling rocket engine | Brian | Main CFD Forum | 0 | November 12, 2003 06:59 |
another question about engine cooling system | marivani | Main CFD Forum | 0 | February 2, 2000 11:55 |
engine cooling system of vehicle | marivani | Main CFD Forum | 1 | February 2, 2000 10:57 |
