August 6, 2003, 10:10 |
Critical cell size
I've performed few grid refinrments, but difference between them is still high (the further the higher). What is the problem here? Maybe there is some 'critical' cell size that all the cells should be kept bigger than it?
August 6, 2003, 13:31 |
Re: Critical cell size
there probably isn't a problem, you're just capturing more detail. When you say a few refinements what do you mean? Generally one should refine in areas of steep gradients, you can do this in the grid refinement panel. Also you should be solving uvw with mars.
allan |
August 6, 2003, 14:25 |
I do the refinements in order to check results on grid independence. Every time I make a refinement I compare results of the new run with the results of the previous one. The idea is to obtain a small difference between results. Then I can tell that the model is grid-independent.
I am solving uvw with mars scheme and double precision. |
August 7, 2003, 16:33 |
are you just solving to the default convergence criteria, if so ar the residuals still falling or have they levelled off on each of you models?
allan |
Limit on maximum cell size to minimum cell size ratio | albcem | OpenFOAM Running, Solving & CFD | 2 | October 17, 2011 12:00 |
the 1st cell size from Y+ | ken | Main CFD Forum | 0 | December 11, 2005 08:56 |
cell size | Sam | FLUENT | 2 | March 11, 2005 03:33 |
Cell size | Julie Polyakh | Siemens | 8 | March 22, 2002 11:43 |
Cell size | Roued | Siemens | 1 | November 22, 2001 05:13 |
