subroutine call order
Old   October 23, 2003, 09:14
Default subroutine call order
CMB
This might be problem dependent, but in a general case, using SIMPLE alg. in a steady state problem, which of the following subroutines are called first in an itteration. Say if I would like to call: sorent.f, sorsca.f and fluinj.f. My guess is that enthalpy changes are calculated in a first instance just after momentum balance, but between fluinj and sorsca I do not really know. I would appreciate any informations about the order in which subroutines are called in Star CD.
Kind regards, C.
Old   October 23, 2003, 11:12
Default Re: subroutine call order
Richard
Why is it important to know? If the coding depends on the coupling of source terms, this should resolve itself by convergence. On the other hand, if you have some procedural requirement like passing information from one subroutine to another or initialising everything in the first subroutine called, you should be able to write FORTRAN that does this without knowing the call sequence. Remember you have the INTFLG array - all subroutines can see it, it's initialised to 0 and it's values are "remembered" by STAR. So you can use it to pass flag from one subroutine to another.
Old   October 24, 2003, 01:54
Thomas
simply write a 'write (*,*) 'blabla-1/2/3...' in each subroutine, then you will see.
Old   October 24, 2003, 04:19
Brian
Ask your CD-adapco representative for a copy of the course material on User Subroutines. It's explained pretty well there, in Chapter 4, but it's too much to paste here, and includes diagrams.
Old   November 26, 2003, 19:08
Default ABOUT INTFLG
Juliet
Hi,experts can you give me detailed information about INTFLG, how to use it, what is it mean?
thanks a lot Juliet
Old   November 27, 2003, 10:34
Default Re: ABOUT INTFLG
CMB
Hi, I am no expert but this is what I know about it, when coding, STAR can help ensuring that something is only executed once and ensuring something is only executed once per itteration/time step. You can use the array intflg for that, the array contains 100 integers which are initialised to zero and which the user is free to modify. STAR does nothing but store them, hence the user can teat them as arbitrary flags.
to ensure that something is executed only once do:
IF (INTFLG(1).EQ.0) THEN C CODE...
INTFLG (1)=1
ENDIF to ensure that this si executed once per itteration do:
INTFLG(2)=-1
INTFLG(1)=1
ENDIF
IF (INTFLG(2).NE.ITER) THEN C CODE...
INTFLG(2) = ITER
ENDIF
this is something I got from the user subroutine adapco course manual, talk to them and ask them to send you a copy, there are some other usefull things in it. Good luck, bye
How can I call EM in subroutine-----sorent.f conglin Siemens 1 November 28, 2008 11:12
Order of Call for STAR Source UDFs Emmanuel Resch Siemens 2 June 25, 2007 05:56
4th order discretization of 2nd order difference dusky.He Main CFD Forum 3 February 14, 2007 08:00
first order time, second order space sven CFX 1 October 27, 2005 13:05
call vertices into subroutine? MG Siemens 2 November 12, 2004 10:48
