POROUS SURFACE MESHING PROBLEM
Old   February 28, 2004, 07:23
Default POROUS SURFACE MESHING PROBLEM
subramani.j
HAI FRIENDS,
I HAVE PROBLEM IN THE AREA OF POROUS AREA (ie GAS DISTRIBUTION SCEENS GD-SCREEN)
TOTAL SURFACE AREA = 2.67 m2 POROUS DIAMETER = 8 mm TOTAL POROUS DIAMETER = 5280 ( CIRCULAR DIA) TOTAL % OF OPENINGS = 30% TO 40%
IN THIS POROUS AREA HOW TO MESH ? HOW TO CALCULATE THE COEFFICIENT PERMEABILITY VALUES,CONSTANTS VALUE LIKE C1,C2,n VALUES.
HOW TO CONSIDER THE PROBLEM,TAKE AS VOLUME OR SOLID? SO PLEASE SEND YOUR SUGGESTIONS & IDEAS.
YOURS FRIENDLY, SUBRAMANI.J
Old   March 3, 2004, 04:45
Default Re: POROUS SURFACE MESHING PROBLEM
carno
In STAR CD porous media are simulated by giving alpha (a) and beta (b) values from the second order polynomial equation passing through origin. y = ax2+bx. y is pressure drop and x is velocity. So from experiment find out these values and directly assign in STAR. Hope this helps.
problem about porous media and surface reaction Jeff Lee FLUENT 3 November 24, 2011 13:46
how to set no-slip on the surface of porous media Nanjiang FLUENT 0 August 7, 2007 13:15
Surface reaction in porous region shuailin FLUENT 0 November 10, 2005 10:57
free surface & porous media Markus Main CFD Forum 2 July 15, 2005 03:24
About Porous wall for thin surface. windhair1 CFX 2 October 14, 2003 05:44
