Divergence in conjugate heat transfer calculation
Old   April 16, 2004, 09:40
Default Divergence in conjugate heat transfer calculation
Julie Polyakh
I perform a simulation of n-heptane combustion within cylindrical combustion chamber. Combustion itself works well, but when I swiched on the conjugate heat transfer calculation, the calcuation diverges after the 1st iteration (mass and dissipation residuals are of order 1e+20). I've tried to set low under-relaxation factors, but it doesn't help... Any ideas?
Thanks in advance,
Julie
Old   May 18, 2004, 13:09
Default Re: Divergence in conjugate heat transfer calculat
Panos
A good idea would be to check your mesh again because it could be a main cause of divergence. It seems that there is another source of inlet. Check your boundaries also
heat transfer in conjugate heat problems cirilo Siemens 1 April 18, 2006 09:16
conjugate heat transfer Rajeev CFX 1 December 23, 2005 03:01
Conjugate Heat Transfer A. Roy Phoenics 1 June 26, 2002 18:35
Conjugate Heat Transfer in 3D Martin FLUENT 2 January 19, 2001 04:20
Conjugate heat transfer Kanghua Chen Main CFD Forum 15 October 11, 1999 14:59
