Divergence in conjugate heat transfer calculation |
April 16, 2004, 09:40 |
I perform a simulation of n-heptane combustion within cylindrical combustion chamber. Combustion itself works well, but when I swiched on the conjugate heat transfer calculation, the calcuation diverges after the 1st iteration (mass and dissipation residuals are of order 1e+20). I've tried to set low under-relaxation factors, but it doesn't help... Any ideas? Thanks in advance, Julie |
May 18, 2004, 13:09 |
Re: Divergence in conjugate heat transfer calculat
A good idea would be to check your mesh again because it could be a main cause of divergence. It seems that there is another source of inlet. Check your boundaries also
heat transfer in conjugate heat problems | cirilo | Siemens | 1 | April 18, 2006 09:16 |
conjugate heat transfer | Rajeev | CFX | 1 | December 23, 2005 03:01 |
Conjugate Heat Transfer | A. Roy | Phoenics | 1 | June 26, 2002 18:35 |
Conjugate Heat Transfer in 3D | Martin | FLUENT | 2 | January 19, 2001 04:20 |
Conjugate heat transfer | Kanghua Chen | Main CFD Forum | 15 | October 11, 1999 14:59 |
