Importing Patran files in Comet
Old   July 13, 2005, 06:29
Default Importing Patran files in Comet
pp
is it possible to import patran mesh file in Comet in a manner that region definitions from imported file will be conserved?
Imported patran input file is crated with external mesh generator.
Regards, pp
Old   July 13, 2005, 09:05
Default Re: Importing Patran files in Comet
4xF
As a rule of thumb: 1) Use the NASTRAN (resp. NASTRAN-L if you use GridGen) format instead of the PATRAN format. PATRAN export does not always work. 2) You will be able to collect the boundary information unless you export the grid using the STAR-CD format.
Hope this helps...
Importing files Meenu FLUENT 0 October 5, 2007 13:35
Importing Patran mesh into Gambit Trac FLUENT 1 September 29, 2005 10:32
Importing Nastran/Patran files in Comet pp Siemens 0 July 11, 2005 08:56
Importing DXF files Seb De La Haye Phoenics 2 December 6, 2003 17:36
Exporting Ideas files into Patran Neutral Dickie Main CFD Forum 0 February 7, 2001 11:39
