MRF with mesh connectivity
Old   May 1, 2006, 04:12
Default MRF with mesh connectivity
Mac
Hi, I am working on a rotor-stator application and using Multiple reference frame model for the same. I wanted to know if MRF can be used with a non-conformal interface (no node-node connectivity) or is it mandatory that the nodes be connected (conformal)?? Please clarify. Thanks in advance.
Old   May 1, 2006, 07:28
Default Re: MRF with mesh connectivity
sham
Hi,if it is MRF explicit, no need of node to node connectivity. use pressure & inlet boundary conditions to couple the boundaries.
cavity_around_longest_edge:mesh connectivity error mariateresa FLUENT 0 September 29, 2005 04:19
about the cell connectivity limingtiger Siemens 3 August 24, 2005 02:51
mesh data structure for zone connectivity Xiaoming Main CFD Forum 0 March 7, 2005 15:33
connectivity check Ted Crilly Siemens 2 January 20, 2005 09:13
please help in connectivity nikhil Siemens 0 December 10, 2002 05:01
