star-ccm+ linux installation..
Old   August 26, 2008, 17:23
Default star-ccm+ linux installation..
NaMe
hi all..
i have some problems with linux installation..
i have installed STAR-CCM+ V3.04. now i can run Star-CCM+ as root.. but i cant as other user.. when i try to create new simulation i got segmentation fault..
what can i do? is there any definition i passed, forgot..
thanks in advance..
Old   September 29, 2008, 10:59
Default Re: star-ccm+ linux installation..
dburns
You need to configure rsh or better yet, configure ssh and use it instead (everyone will tell you that rsh is insecure). at the end of the command to start star-ccm+ just add "-rsh ssh" without the quotes to use ssh instead of rsh. Once you have done that you should be able to run in parallel. However, you must configure ssh permissions for your user if you want to run it as user. google will help tremendously.
Old   September 30, 2008, 09:50
NaMe
thanks a lot...
Gambit installation under linux Alex Main CFD Forum 1 December 4, 2008 01:32
Linux installation sunnysun OpenFOAM Installation 5 May 22, 2008 13:24
Help with new installation on AMD linux 64 bit mattijs OpenFOAM Installation 7 September 29, 2005 15:53
Installation in a 24 linux kernel sampaio OpenFOAM Installation 0 July 20, 2005 17:37
Who have 3.24 linux help file about installation? Kevin Siemens 1 July 8, 2005 08:42
