inner interface
Old   November 11, 2008, 06:01
Default inner interface
MAB
Hi , I have defined two regions while creating geometry and then have imported it into starccm+. I need two define the inner interface where the two regions join each other. both are fluid regions. when i try to convert the face to inner interface it creates a copy as well. now I have one face and one copy in each region all together four where I need only two. any hint please??
Old   November 11, 2008, 07:05
Default Re: inner interface
MAB
I am getting the following message when i try to generate volume mesh.
An edge attached to Boundaries: Face 5, device is attached to an odd number of faces (3). Check surface and interface definitions on these boundaries before proceeding.:
Old   November 11, 2008, 13:45
Adam
Delete whatever copies and interfaces you already created.
Select the two interfaces needed (one from each region), do "Create Interface", "In-Place".
"Convert to interface" should be used if you don't have separate regions already set up. Otherwise, use "Create Interface"
2d interface Rogerio Fernandes Brito CFX 2 July 26, 2008 12:25
interface rym FLUENT 2 January 16, 2008 04:55
About Interface BC Philip FLUENT 0 January 3, 2008 01:51
How to set BC at the interface K Tamemy FLUENT 0 June 5, 2006 10:45
interface braket FLUENT 1 November 15, 2005 01:58
