how to export a mesh from star design to star cd |
March 3, 2009, 12:48 |
hello all,
I will be very gratful if someone can show the procedure to export a mesh from stra design to star cd prostar many thanks |
March 3, 2009, 12:50 |
Re: how to export a mesh from star design to star
hell all,
I will be very grateful if someone can show me the procedure to export a mesh from star design to star cd prostar many thanks |
March 4, 2009, 07:22 |
There are several ways to do that. One is using the dbs with proam:
1. Create a (Volume-) mesh within Star-Design 2. Save the Stardesign-case. This will create a *.dbs -File (amoung others) 3. copy the *.dbs -File as star.dbs into a new working directory 4. Star ProStar/proam 5. In the dbs-entries you will find the surface-mesh and the volume-mesh to work on. |
March 4, 2009, 12:31 |
hi Vamos1,
thank you your guide to get a mesh in star Cd from star design, I do'nt understand how to do the 5 step ( I'm a fluent user but not yet familiarised with star cd ) you say in the 5 step: In the dbs-entries you will find the surface-mesh and the volume-mesh to work on]. would you please be more explicit |
March 6, 2009, 06:22 |
Star uses a *.dbs-File like a database where you can hold different stages or kinds of meshes (surface-meshes, volume-meshes, BLs etc.). You can operate on this database-File via proam and/or via commands (see the dbas-Command). The easiest way is probably to use the proam-GUI:
- start proam in the dir where the dbs-File is located (for ease renam the dbs-File to star.dbs before) - open the proam-Panel (advanced/auto-mesh classic in the menue) - klick on processTool/database summary -> you will see all database-entries in the dbs-File (maybe you have to klick on "refresh" once - you get read in the respective database entry by selecting the entry in the upper area of the proam-GUI and klick "load/get current database. |
Problem wih MESh in Star Design | Waseem Siddique | Siemens | 3 | January 28, 2009 07:19 |
mesh from Star design and use in FLUENT?? | Waseem | Main CFD Forum | 0 | December 17, 2008 06:25 |
Mesh from Star Design in FLUENT | Waseem | Siemens | 0 | December 17, 2008 06:24 |
hi how to do variable mesh in star-design | kathir | Siemens | 1 | June 27, 2006 15:50 |
Mesh export from pro-STAR to STAR-CCM+ | Rostislav | Siemens | 1 | November 25, 2005 14:07 |
