Discrepancy with phi(mass flowrate) calculation at the patch with buoyantSimpleFoam s
Old   April 16, 2021, 02:51
Default Discrepancy with phi(mass flowrate) calculation at the patch with buoyantSimpleFoam s
venu
Venu Angirekula is on a distinguished road
Description:
The problem is related to the way OpenFOAM evaluates the phi(mass flowrate) at
the patch with buoyantSimpleFoam solver. In my system, I implemented a
codedFixedValue BC for inlet velocity, which enters into the space with some
angle from the patch normal. However, the value of phi at the patch produced by
the OF is less than the Original value. Upon observation, it seems that only the
velocity component perpendicular to the patch was considered to generate the
phi. Which disturbs the conservation of heat in the syste
Steps to Reproduce:
I have implemented the velocity profile at the inlet patch in such way that all
velocity vectors are entering into the space radially with 70deg from the patch
normal, as shown in the attached image.
Theoretically mass flowrate calculations:
Volumetric flowrate of patch = 0.02831 m3/sec
Inlet Temperature = 13 deg C
Corresponding Density,rho = 1.238 kg/m3
Supply mass flowrate = 0.03485 kg/sec
But from the OF, with 'flowRatePatch' utility, Mass flowrate = 0.01194 kg/sec.
Which is in accord with direct summation of 'phi' values on the patch.
Nevertheless, there is large difference between the actual supply mass flowrate
and OF generated flowrate.
Upon further investigation, based on "compressibleCreatePhi.H" we found the
calculation of phi
surfaceScalarField phi ( IOobject ( "phi", runTime.timeName(), mesh,
IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), linearInterpolate(rho*U) &
mesh.Sf() );
The calculation of phi on the face :
The surface area vector, Sf ( 0,0,4.032e-05)
The translated velocity vector,U ( 0.93872955,-0.042532896,-0.34202014)
Mass flowrate = (Sf.U)*rho = (0 + 0 + 1.379e-05)*1.238
Please find the case directory here:
https://drive.google.com/file/d/11Fj...ew?usp=sharing.
Observations & Queries:
Why the phi calculations does not taking the contribution of components other
than patch normal velocity.
Based in the above calculations, there is large difference between the actual
supply mass flowrate and OF generated flowrate.
The generated low phi values have also impacted the heat balance of the system.
Venu Angirekula is offline   Reply With Quote
massflowrate, openfoam, phi
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
Warning 097- AB Siemens 6 November 15, 2004 04:41
