Importing data points
Old   May 14, 2012, 12:09
Default Importing data points
bioflow is on a distinguished road
Does anyone know if it's possible (and how to) import a set of data points into Star CCM+ from a table? Looking to import over 100,000 points if possible into my geometry
bioflow is offline   Reply With Quote
Old   May 15, 2012, 11:14
Ryan Coe
ryancoe is on a distinguished road
What do you want to do with the 'points'? Are you trying to create a surface geometry? Or maybe a series of probes?
Ryan
ryancoe is offline   Reply With Quote
Old   May 15, 2012, 11:18
Yes, it's a set of coordinate points that I want to create as a series of probe points
Old   May 15, 2012, 11:24
Ryne Whitehill
rwryne is on a distinguished road
I think you will have to create a macro to do this. Shouldnt be too complicated. You can record yourself making a single point probe, and then modify it from there. Either read in a CSV with your points, or read them from an already imported table.
rwryne is offline   Reply With Quote
Old   May 15, 2012, 11:27
Thanks for the advice, I'll give that a try
Old   May 15, 2012, 11:31
Ryan Coe
Depending the specifics of the application, it may be easier to create a series of points in a CAD program and then save them as an .stl file. You can then import this as an "arbitrary probe."
You can also use the element count and sum reports in combination to easily create an average of any function monitored at the set of probes.
Ryan
Old   May 15, 2012, 13:25
Ryne Whitehill
Thanks, I didn't know about "Arbitrary probe". Seems like it could be quite powerful. Are STL files capable of being just points though? Thought STLs were surface based. If he has 100,000 points, not sure if a surface will describe them.
Importing Points in Design Modeler danh ANSYS Meshing & Geometry 5 March 30, 2015 10:45
XYZ (ASCII format) data points into GAMBIT Neil FLUENT 1 August 7, 2007 09:24
Importing CFX10 data into CFX 11 Stephen CFX 0 May 9, 2007 06:55
Importing curve from formatted data file in ICEM ? Vince CFX 1 April 4, 2007 08:26
Importing data jak CFX 1 May 11, 2004 01:17
