Physic of the field function
Like Tree1Likes
  • 1 Post By abdul099
Old   June 12, 2012, 09:03
Default Physic of the field function
David L
fisicas1 is on a distinguished road
Hi guys
I look for exactly that do a field function of Star ccm+ for calculating WALL Y+, I want to know what? the reason? for using this field fucntion from Star ccm+ ... maybe you could said where I find the definition of the WALL Y+, because I do not find in the help it.
fisicas1 is offline   Reply With Quote
Old   June 12, 2012, 14:18
David L
WALL Y+ is value*u*y/v *where*
u**is the reference velocity,*
y is the normal distance from the centroid to the wall in wall-adjacent cells*
v***is the kinematic viscosity.
Old   June 13, 2012, 08:52
Ryan Coe
ryancoe is on a distinguished road
If I understand your question correctly (not sure if I do):
In general, y+ is used a measure of distance in which parts of the boundary layer can be generally defined (see http://en.wikipedia.org/wiki/Law_of_the_wall).
The wall y+ field function gives the y+ value at the center of the cell closest to a wall. It is a useful measure of how well you mesh is resolving the boundary layer (lower number = better resolution).
Hopefully this helps.
Ryan
ryancoe is offline   Reply With Quote
Old   June 14, 2012, 18:59
David L
thanks so much
Old   June 15, 2012, 15:58
abdul099 is on a distinguished road
I'm sorry Ryan, I have to partly disagree.
A lower number does not automatically mean you better resolve the boundary layer. That's also dependent on the number of layers.
The wall Y+ just let you know if your first cell center is within the viscous layer or in the logarithmic range of the log wall law (or anywhere in between).
A low Y+ doesn't give any advantage when you don't have enough cells to resolve the boundary layer.
LexMedina likes this.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Field function cannot be evaluated on region pauloabeck STAR-CCM+ 2 April 28, 2011 18:40
Force Report help~ or maybe Custom Field Function sailor FLUENT 0 April 13, 2011 03:45
Interface Matching and Field Function problems PLUH STAR-CCM+ 3 July 6, 2009 08:33
