Field Function for interpolating a table to regulate a mass-flow
Old   August 7, 2012, 03:59
Default Field Function for interpolating a table to regulate a mass-flow
Eike
Eike is on a distinguished road
I'm new to using field functions and am looking for a function which can regulate a mass flow or interpolate a table.
I need different values on the mass flow relating to fractions of time. For example 10kg/s from t=0s to t=300s followed by followed by 0kg/s from t=300s to t=600s followed by 10kg/s from t=600s to t=900s
As much more values are intended for the future, I would like to use a table and interpolate it. I could generate a table with time at the first column and mass flow at the second column. What's the field function for interpolating the table? I tried to figure it out, but am not sure if it is correct:
interpolateTable(@Table("mass_flow"), "Time",LINEAR,"Mass_Flow",$Time)
Can you help me with that function?
Eike is offline   Reply With Quote
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 14:03
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 17, 2003 19:23
