Wall treatment - RSM turbulence model
Old   September 10, 2012, 05:34
Default Wall treatment - RSM turbulence model
djack is on a distinguished road
Hi guys,
I'm modelling a cold chamber with Star CCM+ using RSM turbulence model.
With this turbulence model, Star CCM automatically select the high y+ wall treatment because RSM model is more valid when near wall cells are located in the log law region (high y+ value).
However my question is, what's happening when the y+ value falls below the recommanded minimal value (12).
I've read that in Fluent an hybrid wall treatment is available which switch automatically the resolution depending on the y+ value when y+ is above or below 11.225.
Is Star CCM doing the same even if the high y+ wall treatment is selected ?
Thanks,
Djack
djack is offline   Reply With Quote
Old   September 12, 2012, 10:51
abdul099 is on a distinguished road
I don't think so. But you might uncheck "Auto-select recommended models" and choose "Linear Pressure Strain Two-Layer" instead of "Linear Pressure Strain". Then you will have a All-Y+ Wall Treatment available. Please have a look in the user guide, there's an explanation what the All-Y+ wall treatment does:
The All y+ Wall Treatment makes no assumption about how well the viscous sublayer is resolved. By using a blended wall law to estimate shear stress, the result will be similar to the Low y+ wall treatment if the mesh is fine enough. If the mesh is coarse enough (y+ > 30), the wall law is equivalent to a logarithmic profile.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Does realizable k-e model with enhanced wall treatment work for surface roughness? zyy95900 FLUENT 5 November 15, 2017 16:13
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
Use of enhanced wall function in the RSM viscous model for a 3D sector a.hasan FLUENT 0 March 27, 2012 07:40
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
wall roughness with SST turbulence model in CFX10 Vincent CFX 7 September 10, 2007 16:49
