Moment Reports
Old   January 3, 2013, 08:36
Default Moment Reports
Johann
JohannJet is on a distinguished road
Hi everyone,
I'm currently doing some simulation on an opened door with an airflow around it. Simulations are running fine, but for some reason, I do not fully understand the setup of the moment reports.
I want to determine the moment on the door around it's hinge-axis. Air is blowing into a room behind the door and acting on the slightly opened door.
I defined a new coordinate system based exactly on the door hinge and use this as a reference. So do I understand correctly, that I choose this new system as my coordinate system . The Axis origin is 0,0,0 and the axis I want to know the moment of, is the x-Axis - so as Axis I define 1,0,0.
As parts, I only select the door?!
I hope my questions are understandable - otherwise I can try to clarify.
Regards
John
JohannJet is offline   Reply With Quote
Old   January 5, 2013, 17:03
abdul099 is on a distinguished road
Yepp, that's right. The input parts are all parts you want to have the moment. So in your case it should be all door boundaries. And it's self explaining, it wouldn't make any sense to put boundaries you're not interested in a report. But you already got that...
Btw, this principle is the same for all kind of reports except a few special ones where you don't need input parts (e.g. Total Solver Elapsed Time).
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Center of pressure (confirmation/question) scipy FLUENT 2 March 5, 2012 06:54
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Applying a moment to an object daveatstyacht OpenFOAM 0 July 27, 2010 04:35
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 06:56
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 06:51
