heaving of a cylinder
Old   May 6, 2013, 11:03
Default heaving of a cylinder
Arun Krishnan.L.H
arun7328 is on a distinguished road
Hi All,
I have posted this question before but got no replies. I request you to please guide me if you know anything about this problem.
I am trying to evaluate the hydrodynamic force on a cylinder which is heaving with an amplitude of 0.03 m( vertical which is y axis) and frequencies from 1-6 rad/s. The motion is sinusoidal with a velocity of 0.03 cos(wt). I am using morphing for this problem. The results I have attached is for 6.64 rad/sec. I have simulated the problem of swaying and successfully compared the results with experiments.
For heaving I have attached 3 force plots from STAR CCM+.
1. vertical force on the body with pressure only selected.
2. Surface integral of total force.
3. Surface integral of static force.
As per the results the static and total force seems to be the same. The vertical force is lower than what is obtained from 2 and 3. As per the manual Vertical force(pressure), is the surface force that acts on the wall. In that case i assume it must be giving me the total force with the static component?
Why is it then lesser than static and total? Why is the total and static forces equal to each other? How do I get the dynamic component?
The radius of the cylinder is 0.5 m.
Any suggestions would help me. I have gone through all the threads and could not find anything relevant.
Please respond.
Regards
Arun
arun7328 is offline   Reply With Quote
Old   May 9, 2013, 10:47
Arun Krishnan.L.H
Can anyone give some suggestion pls?
Regards
arun
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
A heaving cylinder Henry Arrigo STAR-CCM+ 1 January 10, 2012 05:56
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 9, 2008 23:02
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
