urgent help about cluster
Old   July 11, 2013, 02:44
Default urgent help about cluster
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Hi everybody,
I need to submit a star-ccm job to a cluster, but I do not know how to do that.
The job should be submitted to slurm.
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   July 11, 2013, 09:49
Ryne Whitehill
rwryne is on a distinguished road
Sorry, never dealt with slurm.
Have you tried contacting cd-adapco? Generally they have been very responsive to questions like this for me.
rwryne is offline   Reply With Quote
Old   July 11, 2013, 16:31
siara817's Avatar
Thank you rwryne, I think the issue is mainly related to writing the commands in LINUX.
Good luck
Siamak
Old   July 12, 2013, 02:04
Theodore Kontzias
rickosgr is on a distinguished road
Send a message via Skype™ to rickosgr
I run my thesis in a linux cluster.
Maybe this can help you:
/opt/CD-adapco/StarCCM7.06.012/star/bin/starccm+ -rsh ssh – server –on 195.251.126.227:3,195.251.126.225:3 /media/shared/sims/pipe_porous.sim
The above is the commands in the linux.
I connect via ssh protocol. Also all the clusters must look on the same file, I'm using samba for that.
I hope it helped..
Yours,
rick
rickosgr is offline   Reply With Quote
Old   July 12, 2013, 04:38
siara817's Avatar
Thank you rick,
I wrote the following batch file. what do you think is the problem?
#!/bin/sh
### Job name
#SBATCH --job-name=threephase
### Name of queue to submit to
#SBATCH --time=40:00
### Number of nodes required for the job
#SBATCH --nodes=2
### Number of processor cores
#SBATCH -n 8
### Amount of memory per core
#SBATCH --mem-per-cpu=12000
### The actual job execution
cd /user/siara817/cfdfiles/threephasestest
/pack/STAR-CCM+/starccm+5.02.010 -nodisplay -r threephasestest
Thank you again
Siamak
Old   July 12, 2013, 05:19
Oliver Lauer
olauer is on a distinguished road
What happens, if you use your command? Does it work at all? I am not sure about option '-r' but have never used it.
What I would use is option -np 8 for use of eight processors
olauer is offline   Reply With Quote
Old   July 12, 2013, 05:25
siara817's Avatar
Thanks Oliver,
It gives a Job ID but when I check the job, there is no information, i.e. there is a fail.
Exactly, I have doubt about the last part.
my cfd file is in user/siara817/cfdfiles/
and the cfd software is located in /pack/STAR-CCM+/starccm+5.02.010
I do know if it is the correct way of asking the SLURM to call STAR-CCM to run the file.
Old   July 12, 2013, 06:19
Oliver Lauer
Hm,
in my opinion your last line should look like
/pack/STAR-CCM+/starccm+5.02.010/star/bin/starccm+ -np 8 -batch
threephasestest
to start a running server on 8 procs.
Probably you could add a " > output.log" to the line to have the output of CCM+ directly written to your folder. In this file you could also see the id of your CCM+ server process.
BTW, ccm+5.02 is from April 2010, current version is 8.04
Old   July 14, 2013, 02:22
siara817's Avatar
Thank you Oliver, It seems there is a problem in the server of Cluster.
Good luck
Siamak
Making a Cluster with servers at different locations? Mobz OpenFOAM Programming & Development 1 February 27, 2013 17:16
Parallel rerun in cluster Andy_bm OpenFOAM Running, Solving & CFD 4 November 27, 2011 07:16
Parallel cluster solving with OpenFoam? P2P Cluster? hornig OpenFOAM Programming & Development 8 December 5, 2010 16:06
How to install the OpenFoam in the cluster. Please help me! flying OpenFOAM Installation 6 November 27, 2009 03:00
Linux Cluster Performance with a bi-processor PC M. FLUENT 1 April 22, 2005 09:25
