surface repair problem
Old   July 16, 2013, 14:02
Default surface repair problem
shoumo
amarjogot is on a distinguished road
Hello every one. Hoping every one is doing fine. I am very new to star CCM+. I am trying to run a simulation using tornado vortex chamber. The details are shown in the figure. I try to build the geometry in Star CCM+ but when i repair the surface it showed me 576 pierced surface and 192 face proximity. If possible can any one help me with this problem? the radius of the cylinder is .4m and the inlet is .41m and side wall is 1.66 m.
Zoheb
amarjogot is offline   Reply With Quote
Old   July 16, 2013, 15:51
kw
Kasey is on a distinguished road
How are you building your geometry? I don't think face proximity will be an issue, and likely pierced faces won't either, but the geometry of this seems like it shouldn't be happening. If you are creating the two sections as two seperate cylinders, make sure the two bases that are connected are deleted, and then zip the free edges together. You should have no problems.
Kasey is offline   Reply With Quote
Old   July 17, 2013, 11:20
shoumo
Thank you very much Kasey. Its working absolutely fine. I really appreciate your health.
repair surface, star ccm+
free surface problem with capillary effect rabbitmelon CFX 25 August 16, 2013 03:05
Problem in specifying the boundary condition for tank's surface which is on fire BHE FLUENT 1 March 21, 2013 23:02
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
surface orentation problem in icemcfd jeevan kumar CFX 0 August 18, 2008 04:25
Surface orentation problem in icemcfd jeevan kumar CFX 0 August 13, 2008 01:54
