Transient analysis export to Tecplot360
Like Tree1Likes
  • 1 Post By choiyun
Old   August 21, 2013, 19:43
Smile Transient analysis export to Tecplot360
YunJi Choi
choiyun is on a distinguished road
I am new to star ccm+ as well as tecplot 360. I have been getting lots of help from this forum mostly searching through previous threads, but there is one problem I have encountered recently that I was not able to answer by searching through. I would greatly appreciate your help.
The problem is when I load the exported star ccm+ v7 simulation data into Tecplot 360 2011. I have ran my CFD simulation for 10 seconds using unsteady implicit time marching scheme (dt=0.005sec). Exported my simulation to .plt format including my region, scalars and vectors of interest. Then I loaded it into Tecplot 360, of course the time control (play, forward, stop control) is grayed out because Tecplot 360 did not recognize the time steps in my data (I think this is why).
I tried to play with Edit time strands, but under zones to edit, I only get static zones (body1, outlet, inlet and such) instead of transient zones. To me, there is some sort of confusion between transient zones and static zones when I loaded the data. How can I make Tecplot 360 recognize transient zones of my star ccm+ simulation?
Am I missing a crucial step in my process? Is there a different way to create time animation when using Tecplot 360? I really need your help. I am stuck!
choiyun is offline   Reply With Quote
Old   August 21, 2013, 21:40
YunJi Choi
Problem solved. Simply auto export your simulation for the time interval you would like while you are running the simulationi. I won't delete this post for newbies like me to come.
Old   April 17, 2014, 12:17
Uyan is on a distinguished road
I am having the same problem. When i auto export results from STAR CCM+, it only stores solution data at the working iteration (or timestep). No previous time step values are stored in the .plt file.
So even if i use the Auto-export, in Techplot i can't see time series tools are active, because i have data only at a single time step.
So How did you solve this issue?
Uyan is offline   Reply With Quote
Old   April 18, 2014, 14:52
YunJi Choi
Hello Uyan,
Try
Auto Export>Uncheck "Append to File"
This solved my issue.
Uyan likes this.
Old   April 29, 2014, 13:10
Hi Choiyun ,
Yes that solved my issue.
However this method makes massive data files because it contains whole region.
But for someone who wants to export data along a line probe a monitor can be set up using a report, then export as a table.
So instead of exporting data of the whole region, one can get data at interested locations.
Old   January 18, 2017, 20:08
Default Similar problem but the files are being loaded into tecplot
Akshay Bagi
akshaybagi is on a distinguished road
Hi I have a similar problem. I am running 3D transient simulation. I save .plt files regularly. When I load these files into tecplot I get this error message: "A grid file must be specified before any solution files that depend on it are specified." Can anyone help me on this?
Also the .plt files start from time 2s and not from 0s. I had forgotten to save in the beginning. Is this causing any problem?
akshaybagi is offline   Reply With Quote
star ccm+, tecplot360, time animation
transient analysis thermal-structural Agis CFX 3 June 18, 2013 06:49
Average value of expression in transient flow analysis JFK CFX 1 May 22, 2013 08:52
Transient Analysis krrishcfd CFX 2 July 4, 2011 08:08
TRANSIENT ANALYSIS OF JET FLOW shriramjegan FLUENT 0 July 28, 2007 12:04
Transient periodic analysis & Boundary conditions Michele FLUENT 0 March 25, 2006 16:07
