Filling Holes
Old   September 13, 2013, 11:52
Question Filling Holes
Ali Ertugrul
aliertugrul is on a distinguished road
I have a cable in the middle of my model and there is an outside boundary. When I change dimensions of my cable (via Transform-->Scale), an empty space around the cable is created as well. That means there is a gap between boundary surface of the surroundings and boundary surface of the cable itself. I couldn't find any solution to this problem. The parts are imported into Geometry-->Parts.
P.S. I'm a novice at using STAR-CCM+.
aliertugrul is offline   Reply With Quote
cad, fill, hole, parts, transform
Perforated sheet with hexagonal holes!? oj.bulmer FLUENT 0 April 10, 2013 09:34
[GAMBIT] GAMBIT Meshing of Pipe with Holes Perpendiculer to Flow Stream rocketman1151 ANSYS Meshing & Geometry 7 November 30, 2011 02:39
How to set up meshes of sparse and small holes? leeyee FLOW-3D 1 September 2, 2010 22:50
how to track/view the filling of resin inside a mold using viscid/laminar modelFluent gtuncol FLUENT 0 August 6, 2010 23:49
Flow through multiple holes Matthew Markham Main CFD Forum 3 January 28, 2009 21:47
