Using Variables from multiple Physics Continua in Field Function
Old   October 30, 2013, 16:21
Default Using Variables from multiple Physics Continua in Field Function
cwl
Chaotic Water
cwl is on a distinguished road
Good day, enginners
If there are two Physics Continua (say, Water and Air) in my simulation - which are related to different Regions (so Continua/Variables are not coupled at all) - is there a way to use Variables (say, "Air.Velocity", "Air.Temperature" etc) from one Physics Continua in Field function that is used in another?
For example - i would like to have something like this [written in pseudo-code]:
$$Air.Velocity[0] < 300.0 ? $Water.Temperature*0.5 : pow($Water.Temperature, 2)*0.01
Any ideas?
cwl is offline   Reply With Quote
Old   November 4, 2013, 09:55
Ryan Coe
ryancoe is on a distinguished road
The only way that I know to do this is to use field functions to define the physics continua parameters. For example, you could create a field function named airVelocity
airVelocity = [1, 0, 0.1]
then define physics continua with that field function.
set initial velocity in Continua1 to '$$airVelocity'
This way you can use airVelocity in other field functions and other continua.
Hope this helps.
Ryan
ryancoe is offline   Reply With Quote
Old   November 4, 2013, 10:17
cwl
Chaotic Water
thanx a lot for your answer - but unfortunately that won't work in case that variable is not constant :<
Old   November 4, 2013, 16:23
Ryan Coe
The variable does not need to be constant. You can set the field function variable (airVelocity in my example above) dynamically (e.g., as a function of time or any monitor value that you like).
Am I not understanding your problem correctly?
Ryan
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
User field function for specific heat deifnition crevoise STAR-CCM+ 2 January 28, 2013 04:25
Multiple Physics Continua boathead STAR-CCM+ 6 December 4, 2011 12:33
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
