November 8, 2013, 03:53 |
Volume Mesh in Prism Layer-Any ideas why?
Rep Power: 12 |
Hello everybody,
I am currently facing a problem which is confusing me a lot. I created a volume mesh but realized, that StarCCM also put volume mesh cells in my prism layer. See a picture below: Does anyone of you have'n idea how that could happen? Thanks in advance, Rene |
November 9, 2013, 04:39 |
AHMAD
Rep Power: 12 |
I think that your prism layer is too thick.
Prism layers are generated near the wall to solve near wall functions. There is a method to calculate the prism layer thickness using geometric progression. a=Y+ value r=layer growth Why not try to reduce the thickness first and increase the number of layers instead? just my 2 cents. |
November 10, 2013, 15:36 |
Chaotic Water
Rep Power: 17 |
Depends on Star version; 8.04 happened to have errors in meshing (some primitive geometry case) that 8.06 doesn't.
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner | panpanzhong | OpenFOAM Meshing & Mesh Conversion | 5 | July 3, 2018 05:53 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic | sponiar | OpenFOAM Meshing & Mesh Conversion | 2 | March 30, 2009 15:02 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
