December 18, 2013, 11:09 |
Radiation - Emissivity
Rep Power: 14 |
Hello
I wish to simulate the heat losses and the radiation of an exhaust pipe. For now, I am using the 'convection' option for the heat losses. The radiation is thus mobilized with the surface emissivity. I wish to try the 'environment' option for the heat losses. Thus, for the radiation, in addition to the 'surface emissivity', appears the 'external emissivitiy'. What is the difference between the surface and the external emissivities? Does this external emissivity is relevant in such a case? Thank you for your help and explanations |
December 19, 2013, 08:54 |
siamak rahimi ardkapan
Rep Power: 17 |
External emissivities can be important if the heat exchange between the outer walls of your domain and surrounding environment is significant. I think in your case that you are simulating an exhaust pipe, you can not simulate the whole world around the exhaust pipe. Instead you can use this environment model and external emissivity to consider the heat radiating to environment.
Good luck Siamak |
December 19, 2013, 09:13 |
Rep Power: 14 |
Hello Siamak
Thank you for your answer. There is indeed huge different in the results computations, when activating the 'external radiation'. Compared to StarCD, I did not find any 'external radiation' option, but only the 'surfacic radiation' one. Do you know if there is a way to implement such 'external radiation' in StarCD? Thanks again for your help |
December 20, 2013, 11:42 |
Sergei
Rep Power: 21 |
Take a look at the documentation supplied with the software. It shows how this boundary condition can be used in a particular case with car windows.
external emissivity, heat losses, radiation, surface emissivity |
wall emissivity for radiation problem: emitter is also receiving when it shouldn't | Young | FLUENT | 14 | January 7, 2016 06:08 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 04:12 |
Multiphase radiation in CFX | Luk_Fiz | CFX | 5 | March 17, 2009 03:51 |
Radiation and interfaces | Frank | CFX | 2 | June 22, 2005 11:26 |
