EGR mixing case
Old   February 26, 2013, 06:17
Post EGR mixing case
rajeev50588 is on a distinguished road
Hiii..
In this case i am simulating air and EGR mixing in this nozzle.
i am not willing to give mass flow inlet for EGR (although i have mass flow rates for EGR1 and EGR2 inlets). I want to drive the EGR due to pressure difference in this convergent divergent nozzle.
I have attached the BC's i want to simulate. Would like you to help me with the what exact BC's to be used. If i give mass flow then pressure dsnt matches and vice versa.I have used the following BC's but of no use
a) Inlet - Mass flow , EGR's inlet - stagnation inlet, Outlet - Pressure outlet
b) Inlet - Stagnation inlet, EGR's inlet - Pressure outlet ( with target mass flow) , Outlet - pressure outlet
Physics i have used are as follows:
Ideal gas, K-e turbulence, passive scalars, segregated temp, segregated energy, all y+ etc
Help me out with this
Regards
RD
rajeev50588 is offline   Reply With Quote
Old   February 26, 2013, 06:32
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Have you tried to use pressure outlet for both inlet and outlet?
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   February 26, 2013, 06:45
yes i have done that too...i have mentioned the specified pressure given in the attachmnt for EGR inlet also along with this i have tried the target mass flow rate but of no use...m not getting the results as such
Old   February 14, 2014, 13:20
paul
2pashtet is on a distinguished road
I have the same problem, I need to set pressure + masss flow inlet and pressure outlet.
I try:
1) Inlet - Stagnation pressure (16 atm)
Outlet - mass flow rate
I get solution, where i have the same total pressure on the whole computational domain, it's wrong result
2) Inltet - Pressure outlet (16 atm)
Outlet - Pressure outlet (0 atm) with target mass flow rate
I get solution with wrong mass flow rate
Help me please with advise
Regards
Paul
2pashtet is offline   Reply With Quote
Old   February 14, 2014, 16:03
me3840 is on a distinguished road
IMO the target mass flow option is not very good in STAR-CCM+, you can get better results by coding in the BC using Newton's method in Java.
me3840 is offline   Reply With Quote
Numerical error or case error? Flow in a 3D pipe fsalvucci OpenFOAM 40 January 30, 2013 07:10
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
bc's of a komegaSST case Zymon OpenFOAM 11 July 25, 2010 09:36
Flux update during an MPI run between decomposed case parts? scott OpenFOAM 0 July 21, 2010 20:47
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
