May 15, 2014, 12:00 |
Split a plane surface
Seba
Rep Power: 11 |
Just one stupid question: how can I split a Block face (a plane surface) into more than one boundary?
I need a rectangular face with a circle inscribed into it... and two different boundaries (one for the circle and one for the residual area)... I'm sorry for the stupid question but i can't find how to do it. TY Sebastiano |
May 15, 2014, 21:04 |
Rep Power: 24 |
If you generated the geometry in 3D-CAD, you can easily imprint a cylinder or a sketch with a circle on to the block.
If you're just using the block in the parts tree, you can generate a cylinder as well, open them both in Surface Repair, and intersect the two. |
May 16, 2014, 04:45 |
#3 | |
Seba
Rep Power: 11 |
I did as you said. I selected the block faces first (Face set 1), then the cylinder ones (Face set 2) and clicked "Intersect"... Now the edges of the intersection are selected...and now? I 'm not able to create a new surface with them or a part curve. Failing on easy issue like that is so frustrating -.- Thank you me3840 |
May 16, 2014, 05:09 |
Ping
Rep Power: 20 |
please follow me3840 first suggestion and do this job in 3d-cad since you will need to learn far less
and if you have not used 3d-cad before then do the help tutorial on it designing a cyclone separator |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
Free - Surface Flow: Split Fluid Forces acting on a Boat Hull | eee | CFX | 2 | August 28, 2009 08:36 |
Bug: Surface Integral->Sum w/cut plane and x-face-area | agodfrey | FLUENT | 0 | June 9, 2009 13:11 |
postprocessing - surface - plane | Brujo | FLUENT | 2 | March 1, 2008 10:36 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
