DEM - Pre Processing - Joining two separate mesh regions after some iterations
Old   August 27, 2014, 12:03
Default DEM - Pre Processing - Joining two separate mesh regions after some iterations
Yesaswi
yesaswi92 is on a distinguished road
I am using STAR CCM+ for setting up a transient DEM simulation for particle flow through an orifice. The particles are flowing through a pipe and exit the pipe via an orifice. The particle-flow starts only when the orifice of the pipe is filled properly(). So I use an particle injector in the pipe, let the pipe fill and release the flow once the pipe is filled.
The entire simulation is taking so long and a huge portion of it is being wasted in filing the pipe. Also I need to analyse for different orifices.
So I am thinking of filling the pipe using one default mesh, and stitch(join) that pipe mesh to different orifice geometries and continue the simulation. Is this even possible in Star CCM?
So I need help for the following question
Can we join a mesh region, whose solution is already been done, to a new mesh?
Can we join to separate mesh regions out of which one already has a solution?
yesaswi92 is offline   Reply With Quote
dem, lagrangian particles, packing fraction, particle, star ccm+
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] Propeller mesh not smooth nortanapura OpenFOAM Meshing & Mesh Conversion 0 May 16, 2014 03:26
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Creating mesh regions in ANYS Meshing Tarjei ANSYS Meshing & Geometry 0 February 28, 2011 12:32
