Under Relaxation factors in a transient solution
Old   October 7, 2014, 18:44
Default Under Relaxation factors in a transient solution
Joshua Brickel
JoshuaB is on a distinguished road
I have a question on how Star-CCM+ handles transients solutions when using an under relaxation term.
Traditionally I have done steady state solutions, so the under relaxation terms helped out with convergence. That is u(i+1) = u(i) + R*(u'(i+1) -u(i))
where;
i= iteration
R = Relaxation factor
u = field function be solved for
So for a steady state solution this simply slows down the convergence which can be useful if otherwise the solution will diverge before a proper solution can be found.
However now turning to transient cases....
now "i" is the time step, and thus the relaxation factor while maybe preventing divergence also causes the wrong value to be determined at i+1. If for instance R = 0.5 it is almost like saying you solved for u'(i+1) for time step i, but we will only set it to something between that and u(i). Since we need convergence at each step, this would seem a wrong approach....
I must have something wrong here, can anyone fill me in.
thanks,
Joshua
JoshuaB is offline   Reply With Quote
Old   October 8, 2014, 04:55
David
dai549592484 is on a distinguished road
here "i" should be inner iteration for unsteady case.
You can regard a steady case as a single time step in unsteady case.
dai549592484 is offline   Reply With Quote
Old   October 8, 2014, 15:02
Joshua Brickel
Hi David,
Yep, thanks, that answered the question.
Once I looked into it I realized that the default maximum "inner iterations" was way too low. Hence the solution at each time step was never even getting closer to convergence before the solver was forced on to the next time step.
transient convergence, under-relaxation factor, unsteady flow
Slow Transient Solution scoobysimon FLUENT 1 March 21, 2014 03:19
Under Relaxation Factors in CFX Pre akj Main CFD Forum 0 December 15, 2011 01:50
relaxation factors and time accuracy Mike Main CFD Forum 7 May 21, 2005 12:41
relaxation factors adjust zhujianguo Phoenics 1 July 15, 2003 11:11
relaxation factors Roberto Ciardulli Siemens 3 October 26, 2000 11:35
