zero acceptor cells in region
Old   November 7, 2014, 09:45
Default zero acceptor cells in region
Harshal
harshalh is on a distinguished road
Hello
I am trying to simulate a rigid ship moving body on a water surface with overset mesh in STAR CCM+.
I am getting an error "zero acceptor cells in region" every time I Initialise the solution.
Does anyone know the solution or help me??
Thank you
harshalh is offline   Reply With Quote
Old   November 11, 2014, 09:30
SB123 is on a distinguished road
i means that you need to work to make the overlaping grids closer to the same size. once you are able to do this it should make for an easy transition of data between the two.
also for reference, check steve article 1935
SB123 is offline   Reply With Quote
Old   November 12, 2014, 11:43
Harshal
Hey thanx for the reply and what is steve article?
do u have any link?
Old   December 13, 2014, 15:34
try there first.... steve article number 1935
Old   December 13, 2014, 15:48
Retired Super Moderator
Bruno Santos
do u have any link?
Quick answer - @harshalh: I believe what SB123 meant to point out is that you should look for the following keywords, perhaps in Google:
star-ccm+ steve portal
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
