Regarding Y+
Like Tree1Likes
  • 1 Post By Knigge46
Old   November 18, 2009, 04:16
Thumbs up Regarding Y+
stephenraj
muthuvelcfd is on a distinguished road
hi friend i have one doubt where i have to give the value of y + in starccm during simulation
muthuvelcfd is offline   Reply With Quote
Old   November 18, 2009, 19:28
aerospaceman is on a distinguished road
Hey there,
As I understand it, you control your Y+ by the prism layer meshing settings.
There you can specify 1st wall thickness, total boundary layer thickness, number of cells etc.
These, as you know from your aerodynamics theory,then control your Y+.
If you want a more detailed explanation, let me know and I can supply you with the equations or links to them.
Hope this helps.
aerospaceman is offline   Reply With Quote
Old   December 9, 2009, 08:04
madhu
madcfd is on a distinguished road
hi aerospaceman,
I am wondering how to figure out the boundary layer thickness for a nozzle flow.
Could you give me a detailed explanations, if possible with equations.
madcfd is offline   Reply With Quote
Old   January 3, 2010, 00:36
Default How to control the y+ value in Star-CCM+ ?
nvtrieu is on a distinguished road
Originally Posted by aerospaceman View Post
Hey there,
Hope this helps.
Hello Aerospaceman,
I've been working with Star-CCM+ V3.06. I would like to know how to estimate the y+, as you said by using "prism layer mesher" right? so could you tell me more clearly?
thanks in advance!
email: trieuckgt@gmail.com
MSN: trieu.dut@livemail.com
YM: trieu_tme@yahoo.com
nvtrieu is offline   Reply With Quote
Old   January 7, 2010, 08:24
abdul099 is on a distinguished road
Hi
i'm not sure, if i've understood your problem the right way.
A good estimation for the near wall prism layer of a flat plate could be found by using the tool on http://geolab.larc.nasa.gov/APPS/YPlus/ .
I'm doing simulation on an airfoil, so i specify the near wall prism layer thickness, using the value calculated by this tool, and it works very well.
After the simulation, you should do a scalar plot of the y+ value and adjust the near wall prism layer thickness if the y+ does not meet the requirements.
greetings
abdul099 is offline   Reply With Quote
Old   February 21, 2010, 14:41
Asherah
asherah is on a distinguished road
Originally Posted by abdul099 View Post
Hi
greetings
Hiya thank you for sharing that calculator, in that calculator, there is a refrence length, and output, what are they?
Many thanks
Asherah
asherah is offline   Reply With Quote
Old   February 22, 2010, 02:02
Maddin is on a distinguished road
The output is the thickness of the first layer. For CCM you must calc it with the stretching factor and the numbers of layer.
Maddin is offline   Reply With Quote
Old   February 13, 2015, 04:53
Smile Y+ Calculator
Jan N. Wieczorek
Knigge46 is on a distinguished road
Hi Folks,
I don't know if you noticed, but CFD-Online has it's own Y+-Calculator!
It's very handy and gives you the near wall thickness as an ouput for your desired Y+-value.
It also gives a link to the wiki, where the formulas are explained in detail.
daenerys likes this.
Knigge46 is offline   Reply With Quote
