Export data issue with STar CCM+
Old   March 19, 2015, 00:10
Default Export data issue with STar CCM+
monalisha
mona.16nitr is on a distinguished road
Hello.
I am using STar CCM +. Somebody please help me with how to export the temperature values on the outlet face of a geometry. I want to provide this temperature as an inlet condition to another simulation.
Thanks.
mona.16nitr is offline   Reply With Quote
Old   March 19, 2015, 10:48
Matt
fluid23 is on a distinguished road
Tools > Tables, right click and select New > XYZ Internal Table. Then select the face you want to extract data at in parts and select the scalars you want to output. Then right click Tables > XyzInternalTable and select Extract followed by tabulate. You can then save this in .csv format and bring it in as a File Table in your new analysis. Just make sure that the face your are copying to is in the same location as the face you copied from.
There is also an r internal table that gives scalar as a function of r for axisymetric flows.
fluid23 is offline   Reply With Quote
Old   March 23, 2015, 01:48
monalisha
Thank you so much for d response ! It helped.
Old   March 23, 2015, 10:30
crevoise is on a distinguished road
In addition to MBdonCFD table strategy, does anyone knows if this is possible via a co-simulation?
If for example, the temperature profile changes at every time step at the outlet of the first simulation? We could do a macro to export the table at every time-step, but do you know if this can be achieve by a co-simulation?
Thanks
crevoise is offline   Reply With Quote
Old   March 23, 2015, 12:22
Matt
Unless I fail to grasp what you are trying to do, it seems like that is the very definition of co-simulation. Although, I have never used it. The help files say this:
'STAR-CCM+ allows you to couple two running simulations together in a co-simulation analysis. The STAR-CCM+ to STAR-CCM+ co-simulation capability targets simulations involving conjugate heat transfer (CHT), fluid-structure interaction (FSI) or exchange of scalar/vector fields across a coupling boundary.'
importing ducted fan from catia to star ccm Daniel4 STAR-CCM+ 0 November 3, 2014 09:34
Unable to install OpenFOAM 1.6-ext Maimouna OpenFOAM Installation 23 May 8, 2014 05:47
Macro Issue Exporting Chart Data recon9 CFX 1 March 24, 2011 12:46
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Fluent Export Command Issue .... Leo Hindarto FLUENT 0 January 3, 2009 23:20
