Starccm+ v10.02.010, resume a moving mesh = problem |
March 18, 2015, 11:40 |
I have a DFBI (type boat on a free surface) moving mesh simulation that I was able to run/stop/resume any way I wanted with starccm+ v9. I have opened this simulation with the new v10, it worked and ran. But then I saved it and closed it. When I try to reopen and resume it, I always get the error message "Enabling a DFBI during a time-step is unsupported", and it crashes. I never got that error message before with any previous version. I believe this is not linked to my specific simulation since it can perfectly run on v9 (as long as I do not save it with v10), anybody encountered that ? |
March 18, 2015, 16:53 |
Matt
No. That is fairly specific and the chances of someone on here having encountered that in the few weeks since v10 release are small. I would contact Tech Support, they love development bugs like this.
March 18, 2015, 17:46 |
that's what I figured but we never know.. thanks, so my only option is to open a support case on the steve portal or is there another way (like direct email contact) ?
March 19, 2015, 07:56 |
Matt
Steve Portal is the easiest. Create a case, be descriptive, give your email/phone (if you are at a large company or school), and your DSE will contact you.
March 28, 2015, 11:44 |
If you do end up contacting support and getting an answer from them, we would love to hear about it!
April 9, 2015, 12:10 |
I got a reply from the support, and in fact, unlike with the previous versions, in order to resume this type of simulation it has to be saved at the end of a time step. It does not work anymore when we save during a time step, so be careful if your autosave criterion is set to iteration instead of time step.
Saving at the end of a time step makes sense and I thought I was doing so, until I realized that because I was using an iteration criterion for the auto save, it actually did not save when I expected. For example, most of the time I have 5 iterations per time step, and say I have an auto save like [...]@35000.sim, I would guess it corresponds to the end of a time step, but for this simulation it was not the case, it was actually in the middle of the 6999th timestep, which I did not expect. |
August 12, 2015, 23:11 |
This has been fixed in 10.04.009 - maybe you can import your model to this version and resume.
August 13, 2015, 11:59 |
Yes you are right, thanks!
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
Question on moving mesh, mesh velocity is really small! | ripperjack | Main CFD Forum | 2 | April 28, 2014 13:37 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
