Wall Distance Limited to 10e-06
Like Tree1Likes
  • 1 Post By fluid23
Old   April 17, 2015, 07:12
Default Wall Distance Limited to 10e-06
newbie384 is on a distinguished road
Hi. I have a model with very fine mesh near the wall, yplus~1. When I run the simulation, I got the message "Wall Distance Limited to 10e-06 on n cells ....". I was using single precision and I thought this was the reason. However, the same message appeared as well although I used double precision. Does anyone know why this happens and how to get rid of it? Thanks in advance.
newbie384 is offline   Reply With Quote
Old   April 22, 2015, 17:08
Matt
fluid23 is on a distinguished road
Look under Continua > Physics > Reference Values > Minimum Allowable Wall Distance.
However, I wouldn't just go discarding settings without knowing what they are and how they impact your analysis.
Help files say that it is only used on degenerate cells that return a negative or near zero wall distance to keep the turbulence calculation stable. If you are seeing a warning about this then you might have mesh issues that need to be resolved still. If your near wall cell sizes are the order of 10^-6 then you could maybe think about lowering the minimum value, but if your cell sizes are larger than this value it indicates degenerate cells.
Some options:
-Use cell quality remediation (physics models).
-Add optimization cycles and increase the quality threshold under Continua > Mesh 1 > Models > Polyhedral Mesher.
-Run mesh quality analyzer (from macrohut on steve portal) to identify problem cells for more localized repair.
senthur likes this.
fluid23 is offline   Reply With Quote
Limited wall distance CFDBuddha FLUENT 1 March 15, 2019 23:52
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 11:55
[mesh manipulation] mergeMeshes problem Attesz OpenFOAM Meshing & Mesh Conversion 3 July 29, 2015 04:15
Wrong wall distance with cyclic boundaries sebastian OpenFOAM Bugs 4 October 31, 2012 10:24
