June 8, 2015, 09:57 |
Missing Time Steps?
Oliver Westbrook-Netheton
Rep Power: 12 |
I have just run a simulation with a time step of 0.0005s. The .simh file is twice as large as the previous simulation I ran with a time step of 0.001s (makes sense as they both use the same mesh and initial conditions (apart from the time step)).
However, when exporting lift coefficient data, the time step appears to only be 0.001s. I am sure the simulation ran with the correct time step entered. How can I access/export all data points? Thanks. Oliver. |
June 29, 2015, 23:04 |
Rep Power: 24 |
Check the monitor on your life coefficient and ensure it's being reported at every timestep.
Elastic or Plastic Deformations in OpenFOAM | NickolasPl | OpenFOAM Pre-Processing | 36 | September 23, 2023 08:22 |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
