June 25, 2015, 07:32 |
periodic channel flow
Rep Power: 11 |
I know there have been similar topics in the past, but I would like to be absolutely sure that I'm doing everything correctly. I'm not normally using starccm+, the reason I'm using it now is to validate some results. None of my colleagues can help me so:
I want to run a periodic channel flow (incompressible) with heat transfer (passive scalar transport). (so I want a fully developed flow in a channel). I have a wall with constant heat flux. 1. I define inlet and outlet as periodic 2. Set inlet to velocity inlet, outlet to flow-split outlet 3. In interface boundary, I select fully developed interface boundary 4. in fully developed energy option I select constant heat flux walls 5. for flow I select mass flow rate 6. I specify bulk inlet temperature. So my question is: is this procedure correct? I read the manual, but I wasn't able to find an answer on this question inside. Thank you very much for reading,
beep-beep Last edited by roadRunner; June 25, 2015 at 07:33. Reason: divu=0 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
[ICEM] periodic blocking - blade-to-blade turbine flow volume | Jonathan | ANSYS Meshing & Geometry | 7 | July 11, 2014 19:40 |
Periodic boundary in unsteady flow | ac2011 | FLUENT | 0 | September 26, 2011 06:52 |
Yacht in Open Channel Flow | andreimour | FLUENT | 1 | October 14, 2010 23:54 |
periodic boundaries - flow through a net | PK | FLUENT | 0 | July 12, 2007 11:58 |
