July 27, 2015, 16:54 |
Electrons in Plasma Flow
Wade
Rep Power: 10 |
Hello All,
I am using Star-CCM+ to model the gas phase chemistry of a glow discharge based in helium. I have had some trouble with figuring out how I could use the reactions model to incorporate electrons into the gas. I also need to design gases for each of the different ions that are present in the plasma (N2+, H2O+, etc.) Does anyone have suggestions on how to do this? I realize this is primarily an engineering forum rather than a chemistry one, but I thought it would be worth a try to see if someone has experience doing this. Wade |
July 30, 2015, 01:41 |
Gajendra Gulgulia
Hi
I am not a chemistry or DARS expert, not that even I know the fundamentals, but CCM+ is for continuum mechanics simulation (CCM: Computational Continuum Mechanics) and electrons falls in quantum mechanics. you must consult the cd-adapco local support, they might be able to help you with some user code if that's possible. Good Luck |
July 30, 2015, 18:42 |
Wade
Rep Power: 10 |
Thanks, that is a good idea to contact their support. I will do that.
electrons, plasma modeling |
Numerical simulation of DBD plasma actuator induced flow | mukut | OpenFOAM | 5 | January 7, 2014 05:30 |
Non-steady flow simplified for use in Vissim | steamerandy | Main CFD Forum | 0 | October 31, 2011 21:08 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 05:57 |
